Scanline Double Sided Translucency Effect on a Curtain
  • Scanline Double Sided Translucency Effect on a Curtain
    Hi everyone,
    There was a fine trick to get the shadows on one side of a curtain onto the other one, by using a double sided material and setting the translucency something above zero - with scanline.
    Now does anyone know how to achieve this effect with vray? (Maybe not having to wait hours with real translucency....)
    Thanks in advance
    Andras
    where is translucency im maxes default shatder??
    ya mean transparent?
      Double Sided Materials have a parameter called translucency that determines how much of the 'back'-side of the material gets onto the 'front' one.
      You are absolutely right: Standard materials don't have something like that.
      Andras
        Seems like nobody has an answer to this one.
        Did I actually define my problem correctly?
        Andras
          Look for a plug-in called BACKLIGHT on www.maxplugins.de
          Two heads are better than one ...
          ....but some head is better than none.....
            Szoval mi a gondod? Ha jol veszem ki a szavaidbol en a helyedben adnek egy jo adag refractiont neki meg glossyt. Es lon csoda
            Csinaltam mar ezzel a technikaval szep attetszo selymet. Tutko befuto.
            Mr. Rosenman-nak van egy jo tutorialja, megnem mondom fejbol hol. Absorption -nal keress ra valahol meglesz. Ott szep peldak vannak ra.
            Ha nagyon nem megy dobj egy emilt es kuldok materialt.
            Egyeltalan melyikat hasznalod vray free/demo?
              Thanks for the info guys!
              Backlight does it.
              Andras
                hi there,
                since max 5 translucency is a standard shader in max
                you can access it in a standard material where you
                can choose blinn, phong etc.
                There should be a point "Translucent Shader"
                wich will give you the additional options "translucent color"
                and "filter color"
                and it works great with Vray
                cheers
