Merging vrmap's
  • Merging vrmap's
    Hello,
    I have not been on the forum for a while and I have a question. Is there a quicker way to merge vrmap’s then using the IR map viewer? I have several large maps to merge together and it is taking several hours to merge the maps via the viewer.
    Thanks,
    Scott.
    You can use the viewer to merge the maps via command line as described here: http://www.spot3d.com/vray/help/200R...imapviewer.htm
    That should be faster I think. Also you can load several maps and write them in one go.
    www.hofer-krol.de
    Visualization | Animation | Compositing
      Thanks but........this may be a stupid question but what command line are you referring to?
        Look for "Command Prompt" in your Windows start menu.
        http://www.youtube.com/watch?v=xw7uSgY-aPg
        www.hofer-krol.de
          Oh…ok……the windows command line. I thought you were referring to a command line in IR map viewer that I did not know about.
          Thanks for the help.
            Originally posted by Smalerbi View Post
            Hello,
            Thanks,
            Scott.
            This is odd, how large are the files? Are they on a network drive?
