Is there any way to get multiple alphas from vray in one render?
Multiple Alphas
Tags: None
I meant if I can set Alpha IDs on objects, or something like that. Get alphas for different parts in only one render.http://www.cgpro.se - Portfolio
Hmm, I have tried those element but I don't really understand how they work. I don't get alphas, only wirecolor-like renders.http://www.cgpro.se - Portfolio
The Multimatte renderelement is based on the fact that there are 3 distinct channels in an rgb image. red, green and blue. As they are completely seperate channels you can just take either of them and have an alpha (as in greyscale matte channel). This way you can have up to 3 alphas (or mattes) per element. You can have as many elements as you like and mix materialIDs and objectIDs as needed/wanted.
Regards,
Thorsten
Right, so they are pure red, green or blue. But thats three colors.. only three alphas?
Edit*
oh nevermind, you get it as mattes so different MultiMatte elements shows different objects.. more or less.
I guess that if (or should I say when) vray can output premultiplied alpha, this wont work very well?
Anyone know why vray can't output premultiplied alpha? We have had some major issues with that..Last edited by fAEkE; 05-12-2011, 04:20 AM.http://www.cgpro.se - Portfolio
I assume you mean unpremultiplied ? MMREs and Alphas are both premultiplied by default. Turning off filtering for an MMRE results in unpremultiplied alphas. IF you need raw seperation, then you have to sperate beauties too. You can do that using the VRayObjSelect.
Regards,
Thorsten
Sry, I meant that "When vray can output Straight alpha". I blame my current diet, can't use my head without carbs.. :P
Just disabling filter wont work very well, we can't use an alpha without AA? We need straight alpha for our comps. Is there a way to do that i Vray? Alot of ppl must have the same problem..http://www.cgpro.se - Portfolio
@rivoli
Ye I just tried it myself, works fine, but it's a pretty weird way to get more alphashttp://www.cgpro.se - Portfolio
I you need many "Alphas" and a streamlined workflow for that: MatteShooter
Daniel
psd-manager DeveloperDaniel Schmidt - Developer of psd-manager
dans, is that premultiplied or straight alpha?
We have more issues when working with AE than PS tho, so I dunno if that would help us.http://www.cgpro.se - Portfolio
