VRayDomeEnv texture
  • #31
    max2013 version is requested !!
    This feature is not embedded in VRayHDRI tex? (next SP)
    Thanx
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    • #32
      I wanted to bump this, Vlado. I was looking for it in the Vray HDRI shader but couldn't find it? Did it ever get put in, or is it still a plugin? If so, is there one for 2.4x/2013?
      Thanks very much!
      -Alan
      • #33
        The one mentioned in the first post of this thread works with 2.4x and 3dsMax 2013.
        - Jeff Patton -
        http://jeffpatton.net/
        • #34
          Thanks Jeff!
          -Alan
          • #35
            hello!
            i miss something here or why i dont get any shadow of the teapot on the DomeEnv?
            as i can see here, it should work well...
            • #36
              It doesn't create shadows from your geometry onto the HDR environment. It just maps the environment in a hemispherical mode rather than the usual spherical setup. For shadows you'll still need to use the typical matte options.
              - Jeff Patton -
              • #37
                thank you Pixelperfectg, i should know this...
                • #38
                  +1 for the maya version
                  Best Regards,
                  Sangho
                  • #39
                    anyone use it for maya? if so a tutorial would be nice =)
                    PLAY
                    www.kriscabrera.com
                    kris@kriscabrera.com
                    • #40
                      The version for 3dsMax2015 of VRayDomeEnv is requested. (for V-Ray 2.x User)
                      Thanx!!
                      oakcorp.net
                      v-ray.jp
                      • #41
                        Is there any tutorial on how to use VRayDomeEnv? where should i apply VRayDomeEnv to? a geometry or vraylight?
                        Is it support 3ds max design 2014 and vray 2.4?
                        Regards,
                        Jackie
                        Jackie Teh
                        3ds Max 2023, V-Ray 7 Update 1 [7.10.00 build 00000]
                        AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
                        Website: https://www.sporadicstudio.com
                        Email: info@sporadicstudio.com
                        YouTube: https://www.youtube.com/c/SporadicStudio
                        • #42
                          It is applied as an environment map.
                          I don't think we have it compiled for 3ds Max 2014. I will try to compile it when I get a chance.
                          • #43
                            Thank you very much, where can i get it?
                            Jackie Teh
