hi guys (and j_bug) :
i followed tutorials from here http://www.visualart.ro/tutorials/hdri/hdri_e.htm
i am a bit confused here ... currently i am using 2 hdri maps as in the tutorials ... one is under max environment map, and the other one is under vray environment map ...
let's say if i switch OFF the one in the MAX Environment map :
I lost my background and the reflection on objects, and the scene become dimmer / darker. ( See. Image A )
if i swith OFF the one in VRAY Environment map :
The background appears, and the scene become brighter. ( See. Image B )
if i switch ON both VRAY and MAX Environment map :
The scene become perfect .... but ... the background appears there. ( See. Image C )
The question is :
1. are you guys always use 2 hdri maps, which is one on MAX and the other one on VRAY Environment ? Which is the correct way of using HDRI?
2. how to eliminate the background, while maintaining the brightness of the scene ( and the reflection of the scene )
Thanks a million
