Workstation build advice
  • Workstation build advice
    I need help with building a workstation....
    I cannot decide performance wise
    Either single P4 @ 3.2 HT
    or dual Athlon 3.4
    also....how many gigs of RAM would doit....I was thinking of 2GB...is that enough?
    I really need fast system....I would appreciate your advice.
    Thanks in advance.
    ....also what kind of MBoards would you recommend for that kind of HW....
    in order to answer to this neverending question, it'd be usefull to know what you plan to do with.
    For example.
    A dual AMD will be stable and smooth to use if you switch between apps, but quite noisy for a multipurpose home computer (watching movies?).
    The same with HDs (10.000rpm Satas are top notch but noisy).
    Concernign the memory, if you plan to do 3d (as I gues ) you'll need at least 1gig of ram (ECC registered for Dual motherboards) if you render on this system (without bitmap pager for example).
    etc, etc... Not so obvious in fact.
    (pssst, your message will fit well into the 'take 5' category)
      Thanx for advice....
        I plan to use it for arch/viz renderings.....
        I idea was:
        P4 3.06 HT on 875 chipset
        2gb RAM 400Mhz CL2 (KIT 2x1024)
        ATI RADEON 9800 XT 256MB RAM
        Sorry guys for posting this topic here...Ill try not to do it next time
          You should definately take a look at the discreet support forums. Look under the Hardware section. I think you will find answers to any question you care to ask.
          http://support.discreet.com
