Network rendering Problem..........Help
  • Network rendering Problem..........Help
    Hi
    I have an Issue with the network rendering.
    I have the lastest build of Vray.
    Max 2013
    WP 7
    I have run one job through Back burner 2013, and it worked.
    When I run Distribution rendering, it starts looking for the other machine, and no log message till the end when the spawner crashes on the render slave.
    I have the firewall turned off also.
    Help Please I have tried everything, driving me nuts.
    Thank you
    phil
    Can you give some more details about this issue.
    Do you use identical V-ray versions on all render nodes?
    Do you have stable "vraydummy..." on the slaves?
    Can you post the "VRSpawner.log" files from the workstation and one of the slaves?
    Tashko Zashev | chaos.com
      Hi
      Thank you for the reply.
      Please find attached a screen grab of the results.
      I am on the latest build of Vray on both main and slaveClick image for larger version
Name:	screen grab .jpg
ID:	845940, and 3D studio Max 2013.
      WP 7.
      12 gb ram
      gtx 460
      Dell precision 690.
      Thank you
      phil
        From the screenshot Log can be seen that the render slave has been started for the previous render.
Name:	screen grab _.jpg
        Is it right?
        If you are trying to make second render right after the first one, such an issue is expected.
          To be honest I am not too sure.
          I have foloowed the install and set up to the T, and i am still getting ip address busy?
          So Any idea?
          phil
            Do you have stable dummy, check the V-Ray spawner on the slave taskbar, you should have "vraydummy2013.exe"?
            Are you logged as administrator to this PC?
              Hi I am very sorry for the delay again.
              I have to keep working to get the images out, as I am sure you are aware.
              Yes I am using the correct vray dummy.
              and I am logged in as administrator.
              It is the process that gets me every time I have upgrade to the latest max, I have no network rendering for weeks as i have to go through this problem every year.
              Seems to be very complex every time and always the back burner issue.
              Can this be dropped out of the equation in any way?
              Phil
                Can you post the VRayLog.txt (in the Temp directory) file from render slave as soon as you get this error.
                Also try to use the option "restart slaves on render end" and make another test.
                  Hello,
                  after a installation of a new max version and before you can use DR with backburner you have to run one time a dummy render job (just a few teapots) on every slave computer.
                  Best regards
                  Alex
