Dof
  • Dof
    how long should DOF add to your render times? I am using the default 8 subdivisions, but it seems to be a huge hit. With DOF I am seeing 20hrs, and without, I am seeing 6hrs render times.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    I suggest post effect DOF...
      I usually do, but it seems to turn out nicer in vray
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Have u considered tweaking up ur post effect work flow to get nicer DOF ?
          I consider everything
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            With all of the unified sampling stuff it shouldn't add massively since it should be turning down the samples of other parts in your render. Maybe have a look at the shade map discussion? It seems to have pretty big impacts on render times, especially for stills!
              I have some success using PS's lens blur, using the zdepth channel, but it's not as nice. Of coarse, it's faster, but it doesn't look as good. Other than PS, what would you suggest trying?
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                DOF pro is the only one worth using imo.
                  my shaders aren't changing. When I render with dof on, it's 20 hours and off, it's 10 hours. Nothing, other than DOF, is being changed.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I had that, but I didn't really use it. I got it to animate the DOF, but I never figured it out. I'll check it out again
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Righty - maybe try massively upping the dof subdivs? Try doing a single bucket with your current settings, then try using 25, 50 and 100 subdivs on your dof. You might be able to reduce a lot of subdivs of other parts of the image with everything being blurred instead.
                        gotcha! I'll give it a go.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Umh... id suggest http://www.frischluft.com/lenscare/index.php
                            Lenscare and DOF Pro are both excellent, but neither is really the same thing as in-camera DOF. For a lot of stuff you can get away with it, but for really hi-res or high detail I find too many edge artifacts show up, and there's always oddness with refractive objects and fuzzy edges etc.
                            For me it's worth living with the render time hit 99% of the time. I really like both those filters for adding blur to photographs though
                            b
                            Brett Simms
                            www.heavyartillery.com
                            e: brett@heavyartillery.com
                            • #15
                              Very slow rendering raytraced DOF has more to do with how much overlapping geometry there is, than anything else.
                              The more overlapping geometry the more the renderer becomes exponentially slower. Same with Raytraced Mblur
                              The new SHADEMAP [in the Vray steroscopic helper] is able to solve this problem of slow DOF FOREVER ...
                              ---- if you use the shademap, Vray DOF is now SOOOOOO fast it's unbelieveable
                              Give it a go Bobby & you will never look back!
                              There is plenty threads on the forum as to how to use it.
                              Cheers
                              jamie
                              PS.. you can also use the Shademap threashold at 100 [rather than default 1] and get DOF renders so fast & clean you will instantly smile.
