question on reflect/refract depth How much
  • question on reflect/refract depth How much
    Maybe natty could help me
    To ge t correct metal reflection of object behind glass have I to increase the depth value of reflect or refract or together ?
    How can I understand how much have to increase it?
    bye and thanks in advance
    To Natty the scene is similar to your I'm drawing a stair with glass and iron
    bye and thanks and excuse my bad english
    Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
    https://www.facebook.com/essetreddi..../photos_albums
    i always put it up to 15.......no reasons......
      it all depends on the scene. There is no magical number, start @ 5 and render, if you need more go up 2 at a time and render.
        yeah i agree with DaForce there is no magic number....but i start with these values : glass = Colour = Black, Refract: Grey 230, Reflect: grey 50, IOR: 1.4
        Metal = Colour Grey 183, Reflact colour Grey 120, Glossiness 0.7 Subds 10..... dont use Interpolation it tends to blur behind glass..
        well these are my very basic settings that i tend to play with ..
        Natty
        http://www.rendertime.co.uk
          thanks for the replies
          I'll try but with this scene is complicated to test is to sloww to render
          To Natty:
          Wich parameters of depth did u use for your stair scene?
          Maybe it could help me
          bye and thanks again
            just the standard 5
            Natty
              This illustration may help...
              The yellow represents the most basic path.
              The red line is where you should be concerned about reflections back and forth and this is where it can really add up. If you have a reflective/ refractive material on the other side of the internal reflective object you'll need to consider that also.
              --Jon
                J_Bug's illustration is exactly how I figure reflect / refract depth. Just to clarify it a little.. The 1-2 and 4-5 are the object itself, not the faces. Unless you have reflect on backside on, it won't reflect the backside of faces. Which as I understand it won't affect the count anyway.
