opacity map visible in viewport
  • opacity map visible in viewport
    we reverted to direct3d as having many problems with nitrous - but now or opacity maps are not visible in viewport (its working with 3dsmax standard shader....)
    Is it still true that the vray shader doesn´t show opacity in tzhe viewport or do I miss some viewportsetting with direct3d?
    Matthias
    This is still the case, yes. I've sworn to never touch viewport code again unless I really have to
      As a fishy workaround you could use a shell material wich seperates the render from the viewport material.
        good idea - but as i don´t need the "extravrayshaderfeatures" on these opacityobjects i think i can get along with standard material
        Matthias
          Haha! Looks like Max has made it really nice to work with the viewport as a developer
          3LP Team
