Vray Lens Effects - Applied only to an object
  • Vray Lens Effects - Applied only to an object
    Hi!
    I'd like to create a simple little glow around an object with a VrayLightMtl on it.
    Using the Vray Lens Effects it works, but it applies it also to other objects with the same material.
    It's possible to exclude or include objects to the effects?
    Thanks a lot!
    P.s.
    I've tried also the 3dsmax standard Lens EFfects, but when I run the render an error message appears saying:"the following render effects are not sompatible with the bitmap format selected for rendering. The selected bitmap format is: RGBA color 32 bits/channel.
    Hello there,
    Yes you can control on which objects Lens Effect are applied by Object ID , or Material ID options in Mask Parameters on Lens Effect Options.
    Here is one simple example with two spheres with the same LightMtl.
    lens.zip
    Standard 3DSMax Lens Effects are working with Vray - but you have to use 3DSMax Native Frame Buffer - they won't work with VrayFrame Buffer.
