Hello everyone. I was attempting to merge together 3 IR maps, each around 170megs using the IR Map Viewer. I opened up the first map and merged the second map together without an issue but when I attempted to merge the third map, I ran out of virtual memory and the hard drive when nuts. Everything was locked up to the point I had to re-boot the system. My system VM is set to 4092MB and that appears to be maxed out. Is there an way to merge IR maps that requires les resources?
Thanks,
Scott.
Thanks,
Scott.
