What are the tricks to control precisely white balance. For example lets say I'm using some morning sun HDRI to light the scene. I'm getting orange color cast in interior. Now I'm setting camera temperature to get rid of orange and have neutral grey on white walls. But it's hard to get it right there's always some color cast, bluish or yellowish. I'm tryuing to achieve grey color as Bertrand in his White Vicarage work: http://www.flickr.com/photos/bbb3viz...57632462224257
controling white balance problem
Tags: None
Have you tried the "white ball" approach?
Stick a large white ball in the middle of your scene and render. Right click on the brightest spot on the ball and measure RGB. Use that as value as your rgb white balance and rerender. Your white should now be whiteKind Regards,
Morne
Another thing to consider is that you don't always necessarily want your image to be completely balanced. Sometimes a bit of warmth or coolness can be good.Kind Regards,
Richard Birket
http://www.blinkimage.com
Thank you guys! Will do. Just one thing. If I'm not setting my white walls to white white 255.255.255 but 200.200.200. should I also set the ball the same?Luke Szeflinski
:: www.lukx.com cgi
It might be pretty hard to get rid of all color variation via whitebalance because HDRIs usually have a pretty wide range of color. Why not desaturate the HDRI instead?Ville Kiuru
www.flavors.me/vkiuru
As long as your 'ball' is neutral and you pick that with a neutral camera, you have white balanced. However, as others have said, scenes with a complex mix of lighting (daylight/fluro/tungsten/hdr etc) will be difficult to balance completely. Just the same, in fact, as with real world photography.Kind Regards,
Richard Birket
I read a good trick, but it's done in post.
find middle gray in your scene
create a new layer
fill it with 50% gray
change blending mode from normal to difference
add a threshold layer
move the slider to the left and slowly slide to the right until you see black
sample it by holding shift
delete the threshold and the 50% gray layers
get the RBG value of your sample (info window)
average your RGB numbers
apply a curve
go to red, green, blue
pick a point on the curve and nudge to averageLast edited by glorybound; 25-02-2013, 11:52 AM.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- ​Windows 11 Pro
from the comments:
Lighting is just one Peter Guthrie HDR map. It is desaturated in Photoshop,
http://bertrand-benoit.com/blog/2013...#comment-40469
Originally posted by tricky View PostAs long as your 'ball' is neutral and you pick that with a neutral camera, you have white balanced. However, as others have said, scenes with a complex mix of lighting (daylight/fluro/tungsten/hdr etc) will be difficult to balance completely. Just the same, in fact, as with real world photography.
Depending on you scene, sometimes turning up the GI multiplier in Vray properties for the object could dissipate some of the color cast. It will brighten the object up though.
