2 HDRI + VrayDome light's question...matching horizontal rotation?
  • 2 HDRI + VrayDome light's question...matching horizontal rotation?
    I am using 2 dome lights, each with the same hdr (not instanced). One is for environment/reflection and the other is light source. I want to to be able to horizontally rotate the lighting VrayHDRI and have the reflection VrayHDRI rotate equally. How can I link the the HDR maps to do this?
    Daniel Black
    Archtagon LLC
    www.archtagon.com
    You can achieve that easily by wiring the parameters :
    - select your light dome
    - right click > Wire Parameters > Object (VrayLight) > Texture > horizontalRotation
    - click on the second light dome
    - wire it to the exact same path as above
    - The parameters wiring window pops up. I think you want to use a two-way connection in your situation. So choose that, hit connect. Done
    (you can also access the wire function through the Animation menu)
    mekene
      Beautiful! That's exactly what I was looking for! Thx so much
      Daniel Black
      Archtagon LLC
      www.archtagon.com
