3ds max 2014 and gamma correction
  • 3ds max 2014 and gamma correction
    Recently switched to 3ds max 2014 and first thing I noticed that under Gamma/LUT Setup the Input and Output Gamma Settings are missing and are replaced with a new automatic system.
    In 3ds max 2012 I was used to go with 2,2 in the color correction tab and Input 2,2 Output 1,0 in the Max Gamma settings.
    Well now after I render I have to override the gamma before saving again to get the picture I saw during the render process. Or go with 1.0 in the vray gamma correction and use the srgb button in vrayframebuffer. Technically there shouldn't be a difference but since I am a creature of habit I'd like to go back to the old "workflow". Is that possible or do I have do it the other way in the newest Max version?.
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
    do it another way in the new max, depending on your workflow
    Kind Regards,
    Morne
      Well I guess change is inevitable
      Cheers,
      Oliver
        Hi Ralph,
        You can refer to this thread:
        http://www.chaosgroup.com/forums/vbu...835#post581835
        Tashko Zashev | chaos.com
