Can/should displacement be turned off when calc'ing animation pre-passes?
  • Can/should displacement be turned off when calc'ing animation pre-passes?
    I have displacement on my brick walls and cobbled flooring. It looks OK in the still image renders. I now need to animate a camera.
    Can I switch vray (3D) displacement off when calc'ing the passes and switch it on at rendertime, or will these cause issues/slowdown?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    Most likely it won't be a problem.
      That's a good politician's answer Vlado!
      Kind Regards,
      Richard Birket
        If your displacement is not too much it will be fine. Brick walls don't go very deep so you should be fine with your scene
