Faceted artifacts when using bias on vray dirt
  • Faceted artifacts when using bias on vray dirt
    I posted on this forum rather than the max problem forum as I think this is a problem more due to the nature of how the shader works as I tried a similar 3rd party shader once which also did the same.
    I get faceted artefacts when adjusting the bias when it is applied to curved surfaces. Can anyone explain what exactly the bias is doing to cause this? And is there a remedy?
    Win10 x64, 3DS Max 2017 19.0, Vray 3.60.03
    Threadripper 1950x, 64GB RAM, Aurous Gaming 7 x399,
    This is actually bug and we already have it into our system - we will let you know when it is fixed.
      Do you have any idea when this might be? It can be tricky to simulate drips.
        Couldn't give a time range about this fix unfortunately.
        I will make a note to the developers and will increase the priority if possible.
        Tashko Zashev | chaos.com
          That would be great, thanks.
