Batch Render + Render Elements
  • Batch Render + Render Elements
    Hey guys, just wondering what the correct way is to set up batch render for multiple cameras and their render elements.
    I always seem to get this setup wrong in one way or another - I either end up with no render elements, or just one set for a single camera/render, or the last camera's elements will overwrite the previous, etc.
    Help is much appreciated.
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
    We use RPManager for storing all our passes' data and submitting. It's a vital part of my pipeline, but is somewhat complicated.
    http://www.rpmanager.com/
      And without another 3rd party piece of software, is it not possible?
        There is a script named vray batch render pro.
        show me the money!!
          This one's free: http://www.scriptspot.com/3ds-max/sc...l-pass-manager
          But I tried the RPmanager demo the other day and I'm buying it. I think after one complex project you'll forget about the cost.
          You just need to spend an hour watching the tutorials on the website.
          Win10 x64, 3DS Max 2017 19.0, Vray 3.60.03
          Threadripper 1950x, 64GB RAM, Aurous Gaming 7 x399,
            So the general concensus isn't a way to do render elements through batch render without getting some sort of add-on/plugin/3rd party software. Brilliant.
              You can use state sets - but I found them clunky.
                You can disable the VFB and use the 3ds max native frame buffer in this case and all render element will be saved together with the beauty.
                Also you can use the EXR format as output file.
                Edit: another workaround is to use Backburner instead
                Tashko Zashev | chaos.com
                  Will it ever be possible to do it with the VFB enabled?
                    What you can do is to setup each camera to renders different frames sequences. So for example camera01 will be set to 0 to 100 frames, then camera02 set to 101 to 200. Then the elements will work.
                    If you set all you cameras to render 0 to 100 the elements will be over written.
                    Resolution Digital
                    www.resolutiondigital.co.uk
                      Thanks for the ideas guys, will give them a go.
