Might be a stupid question, but please define "a render node".
V-Ray 3.0 for 3ds Max Beta Open!
A machine, so it's not per cpu or per core, so you can have a lot of processors in one machine but it'll only take up a single license. With machines that have a lot of cores though (16 upwards maybe?) there's other vray versions that can make better use of them.
Just wondered does it support MultiScatter? Crashes max for me http://rendering.ru/ru_en/plugins/multiscatter.htmlSimon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
Originally posted by joconnell View PostA machine, so it's not per cpu or per core, so you can have a lot of processors in one machine but it'll only take up a single license. With machines that have a lot of cores though (16 upwards maybe?) there's other vray versions that can make better use of them.Martin
http://www.pixelbox.cz
just summing up if i understand things properly...
when i receive the updated dongle info and install the vray 3.0 alongside the 2.4, it will work and all my nodes shoudl be workging properly with it even if i leave 2.4 vray on them (provided i tend to use vray 3 beta only on my workstation)
can someone confirm this please???
tHANKS!Martin
Yeah you're quite right Martin, one physical machine = 1 license. What Vlado has said though is for machines with more and more cores, there's different builds of vray that can use the cores more efficiently. It might be some of the amd machines where you've got 4 cpus with lots of cores as an example.
ah...i remember that post...its very likely concerning those AMDs onlyMartin
@PIXELBOX_SRO
On Page 2 vlado said:
Originally posted by vlado View PostThe new license server is fully backward compatible with previous V-Ray versions and will work fine. But on the other hand, if you feel uncomfortable, maybe it's better to wait for a few days to see if anything comes up.
man this really sucks!
we still have a decent amount of older renderslaves, which are still good if you have smaller, less memory consuming jobs to render.
now, it doesnt make sense to use them anymore with vray3, because spending extra money for the render-lic doesnt make sense on those older machines.
not sure if this was a smart move chaos group....
Also, I think the amount of render-lics that comes with the main vray lic is way too low. 1 is nothing. why not 10 (like the DR was) or at least 5 lics like you get with maxwell...
I like the idea of the unified model for the slaves to be used from max, maya, etc. But whats with the user version of vray? Does my vray for max grant me to use vray in maya too with vray3.0 ?MBA Studios | 3D Images & Visual Effects
Originally posted by michaelwbell View PostOh Well....Vray 3.0 is around 50% faster at rendering than Vray 2.4 - So i guess we don't need those unlimited render nodes anymore....
when i look at my work, each year a frames takes the same or longer to render, even after i updated to a much faster machine, because the moment you have more power, you add more stuff to the scene.. will be the same with vray3 if it is really 50% faster....
Originally posted by Markus View PostLOL, are you telling me your rendering times really went down in the past years?
I can't find a WBC file to upload! In fact, my dongle doesn't show up where I can see the contents. About all I can get is the License ID number when I hit it with a browser. Please advise. Thanks.
EDIT
Nevermind - Solved!!!David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2024.2.1 Update
V-Ray GPU 6 Update 2.1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAM
Yep, it's very quick, the cost of the ui license has dropped and when you upgrade from 2.x up to 3 you can get really good pricing on render nodes, they end up at 40 euro each if you buy 11 nodes at the same time. It's a bit more than you're used to paying but it's still pretty cheap compared to all the other renderer's pricing
