I have a still that I am working on, but I can't get enough light into the space, or the glass isn't transparent enough. It might not be physically correct, but I would like to see more of the inside, but I can't get my glass to cooperate. Other than rendering with glass, and without glass; merging in PS, is there something I can do? I am using a vray skydome with a vray sun/sky system. Inside, I have furniture, and a floor lamp.
Outside looking in
Outside looking in
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
Bobby Parker
phone: 2188206812
- Windows 11 Pro
I've not done any interior stuff yet in vray but assuming same as mr, and if light portal isn't doing the trick? you can use a additional lights to help. It's not correct but who cares.
Edit - I replied before I saw the image, so portals arnt why you're after.Last edited by DPS; 07-10-2013, 01:48 PM.
I'll a light portal looking in, but that seems wrong.Bobby Parker
phone: 2188206812
- Windows 11 Pro
If you add a reflection & refraction render element, can you see the interior well in the refraction element? I'd adjust the interior using that element and then tweak the window's reflection until there's a nice balance.Brendan Coyle | www.brendancoyle.com
Looking good!
Definitely turn up your lights inside - a photographer would either have to add additional lights to dress the inside or wait until dusk so that the inside and outside exposure levels drop. You can happily turn down your reflections too, a polariser filter on a lens can be used to limit the level of reflections in a real shoot so it's possible.
I think I got it. It was a combination of a couple things, so after tweaking the scene, it rendering the way I want it.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I use "vray raw refraction" render element all the time. In post use Screen as the blending mode.
Also it seems to me that you have too much reflection. If the glass is too reflective, it could block light from going in AND the reflection itself blocks anything that could be visible inside.
As someone else said before, I also recommend you to add light inside.Guido.
Damn physics, eh?Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
www.robertslimbrick.com
I'll get back to this, maybe this weekend. Thanks.Bobby Parker
phone: 2188206812
- Windows 11 Pro
