having to provide many models from my library to a client for use in a larger scene. since some are custom made its ok, but some are from libraries. im guessing this is outside the terms and conditions.. be nice if you could send models as proxies to a client, with the "import as mesh" option disabled. they could render them, but not edit.
locked proxies
The question is, how hard do you want to protect them? We can certainly disable the option in the UI, but someone can just write a tool to read the .vrmesh file itself and extract the data. So do you want the data itself to be encrypted in some way? This is also breakable, of course, but perhaps not that easily. Then again, it depends on the determination of the hacker
i had the same thouht and wish and would vote a for encrypted proxies...and if there would be a way to attach material information right inside the proxy like the vismat xml for vray 3 would make it perfect. no more max files to share libaries!
