Displacement
  • Displacement
    My understanding is 2D and 3D should render just as fast in the later releases if V-Ray. Is this correct? I have a scene that renders nice at a high resolution using 2D, but with 3D it will not fit into the RAM I have. With 3D I can have the edges joined, so 3D is a must. Any tips?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    3D gets caught up in the Uploading Geometry, which takes 3-4 hours.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      using the VRayBmpFilter and dropping the blur seems to help.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        http://macviz.blogspot.co.uk/2013/08/bitmap-tip.html
        Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
        www.robertslimbrick.com
        Cache nothing. Brute force everything.
          Only if you have enough RAM unfortunately. Increasing the dynamic memory limit and perhaps the edge length may help.
            I did turn off filtering, but this script sure looks helpful.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I have my dynamic memory to 12GB and the edge length is 6, but I am literally seeing 12 hr pre-cal and 12 hour render times.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Do you see anything that I can change to speed up my render times? It is stone, which is a good distance from the camera.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Do you need 512 subdivs? I usually lower this value a lot. Between 8 and 24 depending on how dense the geometry I'm displacing already is. I also factor in the final output resolution too.
                  Tim J
                  www.seraph3d.com
                  Senior Generalist
                  Industrial Light & Magic
                  Environment Creation Tutorial
                  Environment Lighting Tutorial
                    Well, I thought 512 was already the bare minimum and I never thought of lowering it more. I'll stop the rendering, lower it, and see what happens.
                    Tim J
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      is your site down, or is it me? http://www.seraph3d.com/
                      Tim J
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        with 24 subdivs, by edges don't meet up nice. I'll bump it up until I get a good balance.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Add a few iterations of meshsmooth (or whatever you need to do if it goes around a corner) to your model and subdivide it in advance before lowering the subdivisions to 8-32. throwing subdivisions that high on a large flat plane is messy & inefficient.
                          If you control the density of the mesh so it drops off further from the camera you can drop this really low and get super optimised displacement.
                            Yes its down right now. I'm hoping to have it back up and running in a few weeks.
                            totally agree with this.
                            www.seraph3d.com
                            Senior Generalist
                            • #15
                              I am dealing with Revit geometry here, so it ain't pretty! I would have to slice every corner, and the arches would be difficult. If I put a meshsmooth on it, it turns into a blog. Is there a script for this kind of geometry like Populate:Terrain for sites?
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
