I have a night scene and is illuminated with downlights? can someone give tips on the setup?
what is the best way to make a Downlight?
what i have done is downloaded the max/viz file from erco.
all the erco lights have the same one multi-subobject material. I go into each material of each subobject and remove all the raytrace materials. I also create an output map on the "lens". I then save each erco light as a seperate max file and merge into the scene.
Arkitec
that´s a great tip, Thanks a Lot, I will like to see one of your renders with IES lights, contact me at MSN if you can: niksoftarg@hotmail.com
I will love to chat with you. I am studying to become an architect myself.
Akitec:
Can you explain this a little further?
"I also create an output map on the "lens"."
Why ?
"I then save each erco light as a seperate max file and merge into the scene."
Why would you want to save them as seperate max files?
Or are you just talking about the many different types lights that you downloaded?
Sorry just a little confused !
