Shadow Pass
  • Shadow Pass
    I thought I asked before, but I can't find it. How is the shadow pass used in post? I would expect to see an inverted lighting pass, but it's not. Actually, now that I think about it, you could invert the lighting pass to darken shadows.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    You can add it on top of the final image to remove shadows. I've used it other ways too but not for a while.
      What blend mode? Nothing really makes sense.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        e: i was wrong. i cant remember how i've used it, I just know i've used it for creating masks and to do stuff to some stills a long time ago.
          I always create it, but never us it.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Glorybound,
            Im assuming your shadow pass is saved on a file that supports Alpha channels. If so, try adding your shadow pass with the blend mode "Add".
              Shadow Render Element could be used to remove shadows in compositing - it basically calculates Lighting information but only in shadows area.
              It is supposed to be used in Plus/Add blending mode.
              Here is one example of its usage.
              1. Simple composition with GI / Lighting / BG render elements:
              2. Adding Shadow Pass in Plus blending mode:
