Long render times for interior architectural renders
  • Long render times for interior architectural renders
    I've been employing alternative techniques for render setup using help from the guys on this forum, and have been learning from the workflow of, amongst others, Grant Warwick whose work is great. There are certainly some clever people on this forum.
    Prior to the GW approach, we have been using solidrocks. Prior to that I was doing things manually, and bodging my way through it. Solidrocks has been very useful as we can quickly get 'reasonable' results without spending lots of testing time. The problem has always been that the results are only ever reasonable. The GW approach gives much more realism and control, but at the expense of render times. To a large extent, we should expect longer render times as we are getting better quality, but this hit is quite massive. For example, I left a couple of renders going over the weekend for a couple of 4k interiors and they were distributed so if all was stable, they used around 8-10 i7 PCs each. The renders took 12 hours and 8 hours to complete.
    The results are great, but I can't have renders taking that long.
    Are there any archviz guys out there who are using the GW approach with high end interiors? Are you coping?
    I have invested a lot of time with this and would hate to have to resort back to solidrocks.
    On the GW lesson number 3, Grant discusses optimising and cleaning an architectural interior scene (supplied by Peter Guthrie I think). The thing is that this scene is soooo simple. There are a couple of walls, a floor and a ceiling and that's about it. The types of scene we work with are luxury apartments - kitchens, bathrooms, living rooms with lots of furniture and fine details all over the place.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    If you could get me a few "typical" scenes to vlado@chaosgroup.com, I will be able to give you more details on how to optimize them. We could profile the rendering to see which parts take the most time; sometimes there are mundane things like forgetting to turn off the 3ds Max bitmap pager, or filling the scene with ColorCorrection maps, or forgetting a Standard material somewhere, or maybe we didn't optimize a particular use case... stuff like that is hard to figure out with looking at the actual scene.
      Any more quick tips like these, Vlado? Would be greatly appreciated
      Alex York
      Founder of Atelier York - Bespoke Architectural Visualisation
      www.atelieryork.co.uk
        I find reflection depth is the biggest culprit. you can slash a render time down to 1/4 or less with no noticeable visual difference if it's been set up with 5 for every material.
          Yes we've started using the GW approach, and Ive definitely seen a jump in render time but also a massive leap in quality.
          Also agree that the scene used in Grants video was super simple, I cant think of any job Ive ever worked on that has been such a simple and empty space!
          I guess it depends how much power you have in the render farm, but renders for us that take any longer than an hour at 4000px is not good enough.
          There are def some inexplicable render time jumps using this workflow, but I put it down to lack of understanding more than anything else.
          Also as cubiclegangster mentions, I've def found the same when reducing reflection depths.
          I tend to have a gazillion colour correct maps in every scene do these really cause a big slowdown?
            What's the GW approach?
            "I have not failed. I've just found 10,000 ways that won't work."
            Thomas A. Edison
              When I remember, I try to do this. Perhaps a quick run of the VMC on my scene is the answer - anything that looks black means I need to up the bounces.
              Kind Regards,
              Richard Birket
                Absolutely agree in increased quality. Its just keeping that under control at the same time. As with most things, its a balance.
                Also agree about anything taking more than an hour being a worry!
                Kind Regards,
                Richard Birket
                  I will zip a scene tomorrow and get it over to you. It will be too big to email - how else can I get a large zip file to you Vlado?
                  Kind Regards,
                  Richard Birket
                    I tend to work on Archviz interiors at about 4k almost exclusively and I've never been able to understand those comments that often get made on the forum along the lines of 'a render should never take this amount of time, you're doing something wrong'.
                    It's like I must be using a completely different piece of software/hardware!
                    To me if you have a lot of VrayBlendmtl's (these days), difficult GI because of the interior setting, a ton of complex textures, multiple light sources (the strongest of which is often coming in through windows), depth of field, displacement and possibly some hair/fur effects - these types of scenes are just going to take a long time to render. They just inherently require a greater amount of render power don't they?
                    I agree the recent optimisation tutorials are helping massively in the understanding of sampling and streamlining times (as does the comments already made about limiting reflection depth)
                    but I still don't imagine scenes of this type (high end complex interiors) flying by at render time. Either that or I'm doing something massively wrong somewhere along the line that I keep repeating!
                    I assume at present that every final render is going to be outsourced to a render farm and that cost forms part of the quoted fee. I quote interiors higher because of this.
                    Also, weirdly enough there seems to be a direct link between the expense of the real life materials specified and the expense of the render!
                    I am interested in any slowdown associated with the ColorCorrection Map though as I use them a lot (but then almost everyone must do). Would using the VrayHDRIloader for the same purpose be the preferable alternative?
                      negligible difference, dont worry about it. hdri loader helps when you're running out of ram.
                      Some of the render times i've seen people talk about on this forum make my head spin. we work on high end interiors and over an hour for a 1080p frame is getting a bit high.
                        It's bizarre - like I said I feel like I'm operating on a different planet from some of the users in terms of render speed. Mind if I ask what sort of times you'd average for a still on a high end interior (something like 4000x2800 px)?
                        I'm sure I'm being pretty careful with my set ups - one thing that did just spring to mind is that I'm usually a bit careless with overall polygon counts (always 3 iterations on turbosmooth at rendertime on most objects) but I thought that was more of an issue with RAM consumption rather than driving render times up incredibly. Don't know why I assume that actually.
                          4k wide would be ideally 6-8 hours on a single i7, up to 12-15 for some particularly elaborate ones.
                            First off I am no expert, far from it. I too have had great results with GW tips and they have helped heaps with quality and render times. Once thing I must say is that even though he says to increase the samples by doubling them, just to see significant results, often you end up with too many samples in certain areas. We tend to forget to reduce the samples again.
                            Too many samples can have just a big impact as too few.
                            jhv
                            • #15
                              It's just tight deadlines, issuing anything between 5 - 15 Hi res renders daily. Its easy to see why even the slightest increase in render time is a bit of a problem.
                              You're right that certain scenes and settings just need more time - but it's time we don't have !
