Using max ray intensity
  • Using max ray intensity
    Should I have sub pixel mapping off now if I use max ray intensity ? Also, does having sub pixel mapping on speed up renders in general ?
    Regards
    Steve
    My Portfolio
    It is not necessary to turn off subpixxel mapping in order to use Max Ray Intensity.
    In most of the cases when subpixel mapping is on the render times are higher not lower - please note that the result is more accurate when this option is off.
      ok thanks for the confirmation.
      Regards
      Steve
      My Portfolio
        OK but what about Max ray intensity?
        Is times lower or higher just with that (if subpixel is off)?
        Kind Regards,
        Morne
          The times should be lower with lower values for Max Ray Intensity.
            default is 20
            can I set it to 5 maybe?
            or even 2?
            Kind Regards,
            Morne
              Don't know if this is a good scene to test, but even with this simple one. Vrayplane, with sphere and planelight, it's a few seconds faster. With no quality difference.
              WITH
              WITHOUT
              edit: defaults at 20
              On a side note, what does the primitives value in the stamp stand for, I can see it has different numbers, but the only thing different between the two renders is the max ray intensity.
              A.
              www.digitaltwins.be
                WITH
                [ATTACH=CONFIG]21359[/ATTACH]
                WITHOUT
                [ATTACH=CONFIG]21360[/ATTACH]
                Could you test it with MRI of 5 please?
                Kind Regards,
                Morne
                  As expected it's a tad slower, clocked in at 37.6 secs, no quality differences.
                  A.
                  www.digitaltwins.be
                    the number of primitives changes?
                    Brendan Coyle | www.brendancoyle.com
                      Yes indeed with MRI it changes. Don't know why either.
                      A.
                      www.digitaltwins.be
                        The number of primitives value sometimes is not updated properly in VFB stamp.
                        Check that value in V-Ray log window - the number there should stay the same regardless MRI value.
                        This bug happens sometimes even without changing anything in the scene - try to render the scene a few subsequent times without any change and you'll notices that the number will change from its real value to something like 840 or 850 ect.
                        I'll make note about it into our system.
                          It is indeed not changing in the Message window.
                          A.
                          www.digitaltwins.be
