Configuring render elements via MaxScript
  • Configuring render elements via MaxScript
    Hi, all!
    I'm writing a custom tool here (actually a macroscript) to set a number of things in VRay, including the render passes, but I hit a wall.
    The thing is I wanted to make the VRayExtraTex pass come already with a VRayDirt map, pre-configured for AO, but can't figure out a way to do so.
    I'm pretty sure it's simple, but as far as my coding habilities go, I can't find a way to do it. Anyone?
    Any help is much appreciated.
    Cheers!
    Rick Eloy
    V-Ray Evangelist, Trainer and Freelancer
    www.behance.net/rickeloy
    can you get around this by loading a preset with the elements saved in it?
      I probably could, but the problem is the map configuration. Presets don't, AFAIK, hold any information about maps that might be used by the render elements. So what I need here is not only the render element itself (which I already did via scripting and was relatively straight forward), but the dirt map to be loaded and pre-configured.
        holds the map fine on my end.
          Hum... gonna check it asap. Thanks!
            Tried it here, cubiclegangster, not to much success. There are also other things I was trying to configure via scripting, for instance the zdepth max distance and a parametric file name system (following Allan McKay's script), and a preset won't do here.
            The goal is to have a dialog box with some parameters available to be configured (on/off and some numeric values as well) without having to actually open V-Ray. A bit more complicated, I'm afraid.
              I didnt mean use the preset instead of a script. i meant have your script load the preset with dirt then do everything else it needs to.
                Here you go:
                Code:
                RE = maxOps.GetCurRenderElementMgr()
                aoDirt = VRayDirt radius:1.0 occluded_color:(color 0 0 0) unoccluded_color:(color 255 255 255) subdivs:12   -- create the VRayDirt map
                re.addRenderElement (VRayExtraTex elementname:"Ambient Occlusion" texture:aoDirt)
                Colin Senner
                  Great stuff, MoonDoggie! Just what I was looking for!
                  Just for the record, this is what I have so far (lots of stuff found on the help files, other figured out myself, and so on...). Nevermind the "noobieness" of the script nor the comments in Portuguese.
                  Code:
                  -- This script is based on Allan McKay's free video TDT 1 (http://www.tdtransformation.com/fe/6...mation-video-1)
                  -- macroscript Renderizar category:"Rick Eloy" Tooltip:"Controle do Render"
                  -- Fecha a caixa de diálogo de render para poder atualizar
                  renderSceneDialog.close()
                  -- Define a variável vr como sendo o VRay
                  vr=renderers.current
                  -- Especifica o diretório onde salvar (pode estar na rede, desde que tenha uma letra fixa)
                  MyDir = "C:/Temp"
                  -- Cria o diretório para os arquivos da cena específica
                  PassName = substring maxfilename 1 (maxfilename.count - 4) -- cria uma variável que é o nome do arquivo SEM o .MAX
                  RenDir = MyDir + "/" + PassName -- variável que define onde salvar e o diretório com o nome da cena
                  MakeDir RenDir -- Efetivamente cria o diretório com os nomes definidos acima
                  RenFile = RenDir + "/" + PassName + ".exr" -- variável que define o nome do arquivo RAW salvo, com a extensão EXR
                  RenFile2 = RenDir + "/" + PassName + ".png" -- variável que define o nome do arquivo NORMAL salvo, com a extensão PNG
                  Se quiser salvar direto pelo frame buffer do Max, descomente essas duas linhas
                  --rendSaveFile = true
                  -- rendoutputfilename = RenFile
                  -- Configura o VRay Frame Buffer
                  vr.output_on = true -- liga o VRayFrameBuffer
                  vr.output_useram = true -- liga ou desliga o Memory frame buffer
                  vr.output_fileOnly = true
                  vr.output_saveFile = true
                  -- vr.output_fileName = RenFile2
                  -- A seguir, desligamos o Get Resolution from Max e definimos manualmente o tamanho do render
                  vr.output_getsetsfrommax = true -- liga ou desliga o Get Resolution
                  vr.output_width = 2000 -- define a largura do render
                  vr.output_height = 1125 -- define a altura do render
                  -- Vai salvar como RAW?
                  vr.output_saveRawFile = true -- liga ou desliga o V-Ray raw image file
                  vr.output_rawFileName = RenFile -- endereço onde salvar
                  vr.output_genpreview = true -- liga ou desliga o Generate Preview quando salvando RAW
                  -- Vai salvar como PNG?
                  vr.output_splitgbuffer = true -- liga ou desliga o Separate Render Channels
                  vr.output_splitfilename = RenFile2 -- define o nome do arquivo que vai ser salvo pelos canais separados (PNG)
                  -- Adicionando os render elements mais comuns
                  elementlist = #(VRayAlpha,VRayBackground,VRayDiffuseFilter,VRayG lobalIllumination,VRayLighting,VRayReflection,VRay Refraction,VRayShadows,VRaySpecular,VRayWireColor, VRayZDepth)
                  re = maxOps.GetCurRenderElementMgr() -- get the current render element manager
                  re.removeallrenderelements() -- remove all renderelements
                  re.numrenderelements() -- get number of render elements
                  -- Adicionando o VRayDirt ao VRayExtraTex
                  aoDirt = VRayDirt radius:10.0 occluded_colorcolor 0 0 0) unoccluded_colorcolor 255 255 255) falloff:1.0 subdivs:32 -- create the VRayDirt map
                  re.addRenderElement (VRayExtraTex elementname:"_RENDER ELEMENTS_Ambient Occlusion" texture:aoDirt)
                  theManager = maxOps.GetRenderElementMgr #Production
                  theManager.numrenderelements()
                  -- adds all renderelements to be rendered.
                  for n in elementlist do
                  re.addrenderelement (n elementname"_RENDER ELEMENTS_"+ (n as string)))
                  format "\nAdded % renderelement" n
                  setsilentmode true -- used to avoid error message when checking the filename of element
