UNC path setup
  • UNC path setup
    Hey,
    Does anyone know an easy way to convert all asset paths to UNC? My new render farm at work requires it now and I keep forgetting to check that all assets are found through their UNC path before rendering.
    Thanks
    Brendan Coyle | www.brendancoyle.com
    There's a tick box in the files tab of the Customize menu > preferences dialog, top left.
      Awesome.
      thanks!
        and for the ones already loaded, just select all the ones with the same path, right click, set path, don't change anything but click ok. It will then convert existing ones to UNC
        Kind Regards,
        Morne
          Yeah, that's what I had been doing - but newer materials kept loading in the old fashion. Hence having to check over and over (or realize once the render started)
          Thanks
            Maybe Dave or Colin or one of those clever maxscript guys can give us a maxscript one liner to change all existing paths for an old scene to UNC?
            Hint hint wink wink
            Could save a lot of time on scenes with a gazzillion paths
            Kind Regards,
            Morne
              Hint hint wink wink
              Aye, but can't you just select the whole list and do a single convert to UNC?
                Hehe yes keep forgetting that the option is there
                Kind Regards,
                Morne
                  filepathfinder pro does it for you, too.
                  Bobby Parker
                  www.bobby-parker.com
                  e-mail: info@bobby-parker.com
                  phone: 2188206812
                  My current hardware setup:
                  • Ryzen 9 5900x CPU
                  • 128gb Vengeance RGB Pro RAM
                  • NVIDIA GeForce RTX 4090 X2
                  • ​Windows 11 Pro
