VRay Lease option
  • VRay Lease option
    I am weighing out some options... I noticed that it would cost $185 per month to lease 3DSMAX and $190 a month to lease V-Ray. Is it strange that a plug-in cost more to lease than the software you use it in? However, to own 3DS Max it would be $3675 and $1,040 for V-Ray. If V-Ray is 1/3 to own, shouldn't it me 1/3 to lease?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Vray is priced the same world wide with currency adjustments (lovely people!), 3dsmax on the other hand is not. It's about 5,500 dollars for 3dsmax for me in Ireland or about 350 a month. The us just ends up getting very cheap pricing on autodesk stuff
      I don't see why.
      Autodesk and ChaosGroup aren't the same company, nor the two softwares are used for the same goals, or on average for the same amount of time (for example, consider the amount of man hours spent within a DCC app to prepare a scene for rendering, versus the amount of time vray renders what's been prepared.) in a given production.
      Add to that the "law of demand", the actual small amount 190$ is (half a day of freelance wage, in the US? I am guessing.), and on queue to this the fact that for 60$ it's probably better for Chaos to not bother at all with licensing and support (which is given, and very personably so at that, even in the case of a lease) and I don't personally see the grounds for a lowering in price, by any stretch of the imagination.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        It cost more to lease V-Ray than 3DSMAX and V-Ray is 1/3 of the price. So, the leasing option for VRay is a lot higher. 3DSMAX is at 5.04% and VRay is at 18.27%
        Right or wrong, that is what it is. Now, a $
        52 a month sounds lovely
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Ha! Only difference is vray is good value for what it's priced at
            Hey, no complaints... it just didn't make much sense.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Very true - 3dsmax has been totally overpriced for years
                The way I see it is if you were working on a 6 month production everyone needs a copy of max for the entire duration - but only a few people would need vray and for less time. only the lighting, shading & rendering people need it really - you'd still spend more on max if you were renting everybody's software.
                  But, there are different needs. Freelancers are typically one man shops. However, one project a month should cover the software expense.
                  VRay = $190
                  3DSMAX = $180
                  Photoshop = $9.95
                  $379.95 a month for the bare bones to do what I do. Probably a lot more for others, but not less.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Ooh! What might be interesting is say you've rented vray for a total of 6 non continuous months during a year, what'd be cool is if they gave you the option of paying something like 200 dollars to then get a permanent license. 520 dollars a year is pretty damn cheap for rental too if your main profession will always involve rendering - 45 dollars a month?
                    I reckon the one month license rental is designed for studios that bring in a load of firepower for a month to finish off a job and since the setup and support cost for a licence is a fixed cost it has to be proportionately higher if chaos are only getting one months income out of it. It's not really designed for someone that's renting the license over the course of a year.
                      This is spot on.
                      Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
                      www.robertslimbrick.com
                      Cache nothing. Brute force everything.
                        There are many considerations that go into this; one is user base - out of all people using 3ds Max, only some use V-Ray. And lot more people use PhotoShop than 3ds Max. The larger the user base, the lower the price can go as you can collect a smaller sum, but out of more people. Also, Autodesk and Adobe very much want to push everyone to rentals and subscription models so this further justifies a lower rental/subscription price. We offer this as an option in case of temporary need for more licenses, but it is not a goal to keep everyone on this type of licenses.
                        We are also not very well equipped technically to handle temporary licensing; if/when we implement an option for easy online licensing, things could be different.
                          There are many considerations that go into this; one is user base - out of all people using 3ds Max, only some use V-Ray. And lot more people use PhotoShop than 3ds Max. The larger the user base, the lower the price can go as you can collect a smaller sum, but out of more people. Also, Autodesk and Adobe very much want to push everyone to rentals and subscription models so this further justifies a lower rental/subscription price. We offer this as an option in case of temporary need for more licenses, but it is not a goal to keep everyone on this type of licenses. We are also not very well equipped technically to handle temporary licensing; if/when we implement an option for easy online licensing, things could be different. Best regards, Vlado
                          makes sense, thanks.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Ouch! You need to lease per 10 node bundles! Now, that doesn't help at all.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              seriously?
                              Lele
                              Disclaimer:
