Lens Effects
  • Lens Effects
    Quick question, nothing too taxing I hope...
    Now that the lens effects are available through the Vfb, do we still have to have it enabled in the environment/effects rollout for it to generate the relevant lens effect pass?
    Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
    www.robertslimbrick.com
    Cache nothing. Brute force everything.
    oo taxing I hope...Now that the lens effects are available through the Vfb, do we still have to have it enabled in the environment/effects rollout for it to generate the relevant lens effect pass?
    I'm not running 3.0 yet, but you can run a quick test on a small scene. I would imagine you do need it enabled; it takes resources to call and it would an unneeded burden if you didn't need it.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      There was a thread on this a little while ago. I think the advice for Vray 3 was to enable Lens Effects in the VFB only and not in Effects rollout at the same time.
      http://forums.chaosgroup.com/showthr...t=LENS+EFFECTS
        Excellent. Thanks chaps.
          You have to enable it in the VFB before you render otherwise it won't calculate it. You don't need to enable it in the effects.
            How do I save the lens effects baked into the image ? or can I only do it using the vrayVFB on method ?
            Regards
            Steve
            My Portfolio
              You need to enable it in environment/effects rollout. Otherwise Object ID and Material ID doesn't work when only enabled in VFB.
              This is a signature.
