AA setting
  • AA setting
    a little problem with the aa:
    my problem: the central jouint of the window disappears on the image (originalk in 1600x1200):
    My setting are Adaptive subdivision, Min rate 1, Max rate 3, Trehold 0.1, Multipass
    What's wrong on my setting ??
    Vince
    Architecture & design Sàrl
    global solution for architecture
    www.architecture-design.ch
    hi
    what are your min max gi settings ?
    Natty
    http://www.rendertime.co.uk
      hello natty,
      thanks for answer
      My setting :
      good evening
      Vince
        mmmm .... no probs there ..
        perhaps increase your light subdivs, they do look a little low.
        or cheat and increase the gap a little
        Natty
          your treshold is very high make it 0.03 or even less if you still have trouble. (I mean if you havent typed wrong > 0.1)
            that is the standard high settings losbellos
            Natty
              I often use simple two-level set to: Min rate 2, Max rate 6, Treshold 0.08, multipass
                Or the quick one I usually do: Photoshop copy/paste....
                Cheers,
                /Thomas
                Eyecadcher Media
                  dist thresh could also be chaned as well. try 0.3
                    I always use .05 for the AA threshold. It will probably solve your problem and doesn't slow it down to much.
                      I agree, turn your Threshold to 0,05. I've got the same problem as you and solved with more quality setting......you know....times goes up!
                      Valerio
