Show map in viewport issue
  • Show map in viewport issue
    Probably a "duh" question, but I'm having a heck of a time with this particular file in getting the materials to show in the viewport.
    Usually, clicking "show map in viewport" does just that. But for whatever reason, nothing I try seems to work. I've looked at material properties, and viewport configurations, but to no avail. Probably something simple.
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2024.2.1 Update
    V-Ray GPU 6 Update 2.1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    [ATTACH=CONFIG]20869[/ATTACH]
    1. do you have UVW mapping applied (sometimes deleting and re-applying the uvw mapping solves it if there's already one applied)
    2. nothing is selected in the subobject of the editable poly/mesh?
    2. did you try show map in viewport only in the diffuse channel?
    A.
    www.digitaltwins.be
      Check the display tab, Display Color - make sure Shaded: is set to Material Color, and not Object Color
      Brendan Coyle | www.brendancoyle.com
        "Display Tab"? Nothing under preferences and only "Display Performance" under Viewport Configuration. Not sure where you mean?
        David Anderson
        Software:
        Windows 10 Pro
        Hardware:
        Puget Systems
        TRX40 EATX
        128GB RAM
          1) Yes, but re-applying didn't help.
          2) No.
          3) Yes.
          Don't know what's going on...
          David Anderson
          Software:
          Windows 10 Pro
          Hardware:
          Puget Systems
          TRX40 EATX
          128GB RAM
            the Display Tab, the tab on the right side of the UI with the icon of a monitor.
              Ahhh... Ureka! Thank you so much.
              David Anderson
              Software:
              Windows 10 Pro
              Hardware:
              Puget Systems
              TRX40 EATX
              128GB RAM
