Is there any way to start spawner and 3ds max on render server with low thread priority?
Any command line parameter or environment variable or something?
if you start spawner through a .cmd file you can declare a command -belownormal this will run any process in below normal state so you dont have to change it in taskmanager everytime.
Yes - this variable works in V-Ray for 3DSMax as well.
Please note that this variable will set how many threads will be used by V-Ray during the rendering which is not the same thing as low thread priority.
You can put a small scrupt in plugins folder (on each machine or on network for everyone) with that :
sysInfo.MAXPriority = #low
I searched internet and found that this script should be named "priority.ms" and should be placed in scripts/startup folder. http://area.autodesk.com/blogs/ken/h...ity_of_3ds_max
Anyway - thanks for suggestions...
You don't have to name it like that, or place it in a particular folder, just a folder that load scripts at startup. You can even put this line of code anywhere in any other startup script.
