low thread priority on render server
  • low thread priority on render server
    Is there any way to start spawner and 3ds max on render server with low thread priority?
    Any command line parameter or environment variable or something?
    Low Thread Priority option works only for the workstation machine.
    You can Set Affinity for VraySpawner from Windows Task Manager for that purpose.
    This topic has been discussed also here:
    http://forums.chaosgroup.com/showthr...finity+spawner
      This is good to know. I'd been checking off low priority recently for DR jobs thinking it would ease the cpu usage in DR.
      Brendan Coyle | www.brendancoyle.com
        Would be cool to have an option for that int he render dialog though
        Software:
        Windows 7 Ultimate x64 SP1
        3ds Max 2016 SP4
        V-Ray Adv 3.60.04
        Hardware:
        64GB RAM
        DxDiag
          if you start spawner through a .cmd file you can declare a command -belownormal this will run any process in below normal state so you dont have to change it in taskmanager everytime.
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
            There is environment variable "VRAY_NUM_THREADS" for V-ray for Maya.
            Is this variable working with max V-ray?
              Yes - this variable works in V-Ray for 3DSMax as well.
              Please note that this variable will set how many threads will be used by V-Ray during the rendering which is not the same thing as low thread priority.
                You can put a small scrupt in plugins folder (on each machine or on network for everyone) with that :
                sysInfo.MAXPriority = #low
                  thanks for answers
                  I know but this is very usefull too..
                  I searched internet and found that this script should be named "priority.ms" and should be placed in scripts/startup folder.
                  http://area.autodesk.com/blogs/ken/h...ity_of_3ds_max
                  Anyway - thanks for suggestions...
                    You don't have to name it like that, or place it in a particular folder, just a folder that load scripts at startup. You can even put this line of code anywhere in any other startup script.
