Matte Element
  • Matte Element
    How do I isolate my matte shadow? I want control in post. Now, it comes in black.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    There is a Matte-Shadow render element which could be used as a mask to control the opacity of the matte-shadow on post:
      Originally posted by svetlozar_draganov View Post
      There is a Matte-Shadow render element which could be used as a mask to control the opacity of the matte-shadow on post: <img src="http://forums.chaosgroup.com/attachment.php?attachmentid=21851"/>
      I found that, but it seems to control all the shadows in the scene.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Yes that's true - I always forget that the Matte-Shadow element contain information about the non-matte shadows as well.
        Fortunately Shadow element doesn't contain information for the matte-shadows so if you extract it from MatteShadow one you'll get the right mask.
        I can show you how to do it Nuke but I am not sure if there are alternative tools in Photoshop.
        The Shadow element cannot be subtracted from the MatteShadow one out of the box since it has different values for R/G/B while the MatteShadow doesn't.
        You have to adjust Shadow element first to be like an Alpha channel not like a RGB-one. In Nuke this could be done via the Clamp-node.
        Here how the passes looks like out of the box.
ID:	854702Click image for larger version
ID:	854703Click image for larger version
        With the help of the Clamp too I could convert the Shadow pass to Alpha:
        Then if you subtract this pass from MatteShadow one you will get only the matte-shadows-mask:
        And then you can use that mask to control the transparency of the matte-shadow without affecting other shadows:
          I'll have to see what I can do in PS, thanks.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
