Sandpaper Material?
  • Sandpaper Material?
    Has anyone ever tried to create a rough sandpaper material. So a really coarse one with nice reflection highlights. Somehow my material isn't giving me the poper results?? Any tip or hint?
    Cheers
    Ralf
    Hard to tell from that image (without any environment to provide some context), but it doesn´t per se look "wrong" in my eyes. I would try to use it on a different object maybe something that resembles an actual folded sandpaper) and with variable light setup to properly test it.
      Have you considered scattering geometry (grains of sand) instead of displacement? PFlow, forest pro, multiscatter could all do it.
      Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
      www.robertslimbrick.com
      Cache nothing. Brute force everything.
        Thx for your answers, the idea of using geometry souds interesting Ill give it a try, cheers
          You can scater it, then bake to displacement, then have a texture for it. You can even bake diffuse/reflection/etc/etc values as well to produce more different maps.
            Use an hdri and light with that, I think you may find it's fine.
              How would you bake a scatter to displacement?
              A.
              www.digitaltwins.be
                Quickest way with a flat object is to use a orthogonal camera facing straight at it and render a z depth pass. The other way is to use a projection modifier on a second object (in this case a plane) to bake from, this is mostly used to bake high poly meshes down to low poly objects for games and stuff like that.
                  You should post an image of the type of sandpaper you are trying to create. What is the grit?
                    Aah thank you I'm familiar with this method I just thought there was like a button I didn't know about
                    A.
                    www.digitaltwins.be
