I am new to Vray and have problem with dark areas under roof and balconies and I think its becouse of low settings for secondary bounces. Where do I control number of secondary bounces becouse I couldnt find it.
dark areas under roof ( exterior )
Tags: None
Thanks. But what does it really means : 0.8
It is much logical in Frender where you can set number of bounces that light ray does after first hit of direct light.
here's a brief explanation.
Secondary diffuse bounces
Multiplier - this determines the effect of secondary diffuse bounces on the scene illumination. Values close to 1.0 may tend to wash out the scene, while values around 0.0 may produce a dark image.
Secondary diffuse bounces method - this parameter determines how VRay will calculate secondary diffuse bounces.
None - no secondary bounces will be computed. Use this option to produce skylit images without indirect color bleeding.
