force 2-sided problem
  • force 2-sided problem
    I have a big trouble.
    I have modelled in rhino and then i have exported in dwg into max.
    When I render I see some surface black. So I check on force 2-sided in "Render scene". In this way I can see all the surface but this works fine only if I use standard material, not if I use vray material. What can I do?
    Thanx
    fabrizio
    hi
    import from Rhino as IGES.. then once in max convert to editable mesh
    Natty
    http://www.rendertime.co.uk
      The problem is errors in the imported mesh, apply a "stl check" modifier and you will see what they are. The most elequent solution is Power Translator from http://www.npowersoftware.com/trans/trans.html.
      Here are some posts where it is discussed:
      http://www.chaoticdimension.com/foru...wer+translator
      A search for "rhino" will produce some other solutions as well.
      Eric Boer
      Dev
        thanx very much to everybody.
        I'll try Iges and npower.
        But why doesn't vray fix this simple problem?
        bye
        fabrizio
          this might be simular. i just recieved my kohler CD collection. and the models are really hacked up and horrible. anyone else have this collection and knows how to get the models to import correctly?
