Background images using Max render tab and RT GPU
  • Background images using Max render tab and RT GPU
    Is is possible to use a background image mapped to environment screen while having an invisible dome light with a texture? It doesn't work that way for me, or I just plain haven't figured it out. The RT GPU seems to use exactly what the viewport can/cannot see.
    If I am wrong, please feel free to correct me. If not, is there anything that can be done about this? Some of the HDRIs I have, specifically Peter Guthrie's, don't have an alpha channel and that's how I set a backplate using CPU.
    Thank you for reading.
    Oh, VRay 3.1, of course.
    Logan
    Omnia Mutantur
    logan683@gmail.com
    Origin Genesis Pro
    -i7 4790K @ 4.5GHz
    -GeForce GTX Titan X @ +200 GPU, +300 Memory x2 non-SLI
    -32GB RAM
    -Windows 10 Professional 64-bit
    It should work, here is the result from my tests render with V-Ray 3.10.03 >
Name:	2015-02-02 14_53_18}.jpg
    Would it be possible to attach the scene file you have problems with ?
    Tashko Zashev | chaos.com
      Sorry, I have been behind.
      Try this scene. Turn on Use Map in Environment under Rendering and hide the Dome Light.
      But in retrospect, admittedly I am not sure I have been doing background images correctly. Could I get a copy of your scene to study?
      Also, the VRay Plane doesn't seem to render GPU, either. Thank you.
      TESTVRay_BG_GPU.zip
      Logan
      Omnia Mutantur
      logan683@gmail.com
      Origin Genesis Pro
      -i7 4790K @ 4.5GHz
      -32GB RAM
        [ATTACH=CONFIG]22748[/ATTACH]
        This is expected as per the list of unsupported features : http://docs.chaosgroup.com/display/V...orted+Features
        mekene
          Thank you, theedge. I didn't mean to miss that on the feature list. I downloaded a copy to keep next to me.
          Logan
          Omnia Mutantur
          logan683@gmail.com
          Origin Genesis Pro
          -i7 4790K @ 4.5GHz
          -32GB RAM
