AO baked into render without using GI?
  • AO baked into render without using GI?
    I would like to bake AO into my animation frames. The scene does not use GI so I can not activate AO on that tab.
    And I do not want to use a seperate pass and multiply in AE
    any ideas on how to achieve this?
    Thanks!
    Arjan Jacques
    makeit3D
    the only way you could do this is probably put your final material/texture through a blend and multiply it by AO map.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Yes that will work and still let me finetune the amount of AO.
      thanks!
      Arjan Jacques
      makeit3D
        You can also use a VRayAmbientLight with a VRayDirt map as its lightmap.
          Thank you! Just did a quick test and it works like a charm. Elegant solution!
          Arjan Jacques
          makeit3D
