After years of using Vray on Max I started looking into the Standalone to be able to render on Linux.
One thing that seems weird is the speed differences that I'm getting.
Here's the actual scene I want to render:
Vray 3ds max - Rendertime: 2mins
Vray Standalone - Rendertime: 2,50mins
You can spot a few differences in the two images probably due to conversion (FOV, Noise Maps, Colours, Lightcache interpolation around Objects) but I don't see why Vray Standalone should take almost a third longer than VrayMax. I build up a small test scene then to figure out if there are particular features that make it slow (maybe noise maps) As it turns out a very simple render with NO textures will give something very similar in rendertime - start adding (simple) things (texture, noise maps, etc) and Vray Standalone takes a much bigger hit than Vray for Max.
I wanted to know if I'm missing something obvious or if it's just the case that Vray Standalone is slower.
