vertical tilt bug
  • vertical tilt bug
    V-Ray Version : 3.10.03
    1. Vertical alignment
    2. Camera Hide
    3. Save
    4. Open file
Name:	vertical tilt_04.jpg
    The vertical tilted.
    Is this a bug?
Name:	vertical tilt_05.jpg
    V-Ray Version : 2.5
    There is no problem.
    I am always a challenge!
    http://blog.naver.com/kjgsgi
    It happens to me in MAX, too.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Is the camera hidden? Can you attach the scene here?
        This happens to me as well, very rarely, though.
        BTW it renders with the correct tilt applied even though it's not applied in the viewport and it snaps back into place if I try to change the view a bit.
          Yeah, it's a viewport thing.
            In Vray 3.10.03 version will appear the same problem in any scene.
            https://www.youtube.com/watch?v=RP7q...ature=youtu.be
              Yes, we are aware of this viewport issue when the V-Ray Physical camera is hidden and we will try to find a way to fix it.
              Update: Just did a quick test using the new Physical Camera in Max 2016 and it works better with this setup.
              Tashko Zashev | chaos.com
                Thank you.
                I hope soon solve this problem.
