Bad Geometry
  • Bad Geometry
    I purchased a bed, but the texture seems to be damaged; maybe a mapping issue. What could cause this and even better, what can fix it?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    First thought is flipped normals, but I'm not sure. Could be badly set up reflections too. It doesn't look like a UV bug, Can you post a picture of the material settings? Unless someone has a better idea
      Is there a normal map applied? If so, gamma for the normal map must be 1.0 and not 2.2 (or something else).
      Tim
        Or normal map set to the wrong space. (world or tangent)
          I ended up importing the FBX version and that one is good. Thanks!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            it could be coplanar faces.....sometimes you would fine the base geometry under "fabrics" ...Most of them were simulated outside of 3ds max
            show me the money!!
