White Balance
  • White Balance
    Do you guys do your white balance in post, or in V-Ray?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    vray then adjust in post
      Okay, that's what I have been doing.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        My general rule is to set the white balance in the vraycam(s) to match my main ceiling spotlights or my sun, then shift it slightly so I achieve the desired look in terms of temp (warmer, cooler etc.). The key thing is to ensure that your other lights are all proper real-world temps so that you have a real balance across the image. You can then work with something with a proper dynamic range of temps in post. Typically I would then whiten up walls etc. as needed to get the desired effect. Exact same principles as in photography.
        Alex York
        Founder of Atelier York - Bespoke Architectural Visualisation
        www.atelieryork.co.uk
