GI pass ?
  • GI pass ?
    How do you break down the GI pass to exchange the diffuse maps as needed ?
    for instance:
    I want to use the VraySamplerInfo UVW pass to exchange texture maps.
    I was not able to find that info.
    Thx a lot !
    www.bernhardrieder.com
    rieder.bernhard@gmail.com
    Diffuse Map * Full lighting = "Beauty" (assuming no reflections, refractions, speculars or environment).
    So the inverse mathematical equation to get Diffuse map from beauty is:
    Diffuse Map * Full Lighting / Full Lighting = Beauty / Full lighting. Cross out our FL/FL since that equals 1.
    Diffuse Map = Beauty / Full Lighting.
    If you rendered GI and Direct Lighting separately then you'll have to add then together to create your full lighting pass. If you didn't render out a raw lighting pass without the diffuse map already multiplied into it and you didn't render an unlit diffuse color pass then you mathematically can't get where you want to go.
    Gavin Greenwalt
    im.thatoneguy[at]gmail.com || Gavin[at]SFStudios.com
    Straightface Studios
      Texture can be easily switched via STMap in Nuke just plug the SamplerInfoUVW pass to stmap-slot and the new texture into src-slot.
      Here is a quick example:
      Here is a raw render with default material with checker-map in the diffuse slot:Click image for larger version
      Here is how the same checker-texture looks like when applied through STMap src-slot: Click image for larger version
      A few more examples with different textures: Click image for larger version
ID:	858364Click image for larger version
      Scene, Nuke script, output elements and texture could be downloaded from here: http://ftp.chaosgroup.com/support/sc...re_exchage.zip
      Regarding the Render Elements formulas:
      GI=RawGI*Diffuse
      You can easily switch textures and update GI render element by multiplying the new diffuse texture by RawGI element.
        Wow, that's awesome!
        Win10 x64, 3DS Max 2017 19.0, Vray 3.60.03
        Threadripper 1950x, 64GB RAM, Aurous Gaming 7 x399,
          Great.. thank you so much.. that's cool.. hmm.. using Fusion.. you might want to kill me now.. but what nodes do you use within Fusion then ? I don't have an STMap node ... at least, not that I am aware of...
            Stop using fusion :P
            http://www.bryanray.name/wordpress/?p=546
