Controlling the near/far transition strength of VrayDistanceTex?
  • Controlling the near/far transition strength of VrayDistanceTex?
    Is there a way to control the strength of the near/far transition in VrayDistanceTex? I need to achieve a certain effect but the current transition which appears to be linear isn't working for me. I would like to make it more exponential so that I have stronger/denser distribution at the very start (the near color/texture) and almost immediately after that have it fade away smoothly to the far color/texture. Please check the screenshot to see what I mean:
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Put it into an output map and use the curve of that!
      Didn't think about that! I'll try it out. Thanks.
      Aleksandar Mitov
      96GB DDR5
        Vlado popped up the same trick for use in toughening up the look of the dirt map - should work the same!
          Hmm.. I tried this but it doesn't change things much. I even tried putting the VrayDistanceTex in a CC node with Gamma of .454 but it just shrinked the overall spread of the effect and didn't modify the attenuation. Interestingly, if I disable "sRGB" in the VFB in order to see the render in linear space,the falloff is what I want it to be. Here's a new screenshot:
          Aleksandar Mitov
          96GB DDR5
            If you like the non-sRGB look (in sRGB space) just use two .454545 colorcorrect nodes. I'm using one CC at .5 right now to simulate omni lights in a particle field. Works very nicely.
            Gavin Greenwalt
            im.thatoneguy[at]gmail.com || Gavin[at]SFStudios.com
            Straightface Studios
              I stuck in one extra point into the output curve to drag the mids further down and right and got this:
              Original
              With output
