Making a stone "dry wall"
  • Making a stone "dry wall"
    Hi guys,
    I need to make something like this
    Similar, our walls will have some mortar.
    I tried with stones that had flattened tops and multiscatter. It was ok but I always had stones sticking out where horizontal and verticals meet. Client didn't like that.
    I guess the other way would be with texture, but since I need it to be rough I need to use displacement. The problem is that my best stone textures are from arroway, and as we discussed a while back in my thread, their bump maps can't really be used as displacement maps.
    So any suggestions for pro stone textures with good displacement maps?
    www.hrvojedesign.com
    You can just model one segment of a wall by placing stones by hand, say 3*3 or 4*4 meters, then duplicate it to one side, and adjust the edges so that it does tile, then do the same thing for the other side. Once you have tileable arrangement, you can just bake displacement map (and any other maps) out of it, and displacement will create something very close to the hand-modeled segment you did. You can then use some procedural map to add some variance to the texture so that the tiling is not so obvious on long segments.
      You can try with railclone...
      http://docs.itoosoft.com/m/view-rend...ageId=19726520
      Rule 10 - Disguise joints with interlocking geometry
      paolo vaja
      www.3d-arch.it
        Interesting option Recon...will see if I'll use that.
        Also paolo, that looks like a great and powerful plug in. I feel it's complicated, but I should try that too.
        thx guys
          Check with Bobby, he had to do something similar not too long ago
          Kind Regards,
          Morne
            Which Bobby? Bobby revolver?
              Bobby Parker (Glorybound)
              Kind Regards,
              Morne
                You can try rayfire bricks methid too i think its more accurate to create semaless wall.
                https://www.youtube.com/watch?v=UJvQ2fFg4lg
                  I purchased a stone wall from 3dsky, which is what I think you are talking about.
                  Bobby Parker
                  www.bobby-parker.com
                  e-mail: info@bobby-parker.com
                  phone: 2188206812
                  My current hardware setup:
                  • Ryzen 9 5900x CPU
                  • 128gb Vengeance RGB Pro RAM
                  • NVIDIA GeForce RTX 4090
                  • ​Windows 11 Pro
                    Rayfire looks awesome, too bad they don't sell just that one modifier.
                    Glory, I already checked 3dsky but I haven't found a good enough texture with a map for displacement.
                      Maybe check this: http://www.scriptspot.com/3ds-max/sc...lacement-tools
                      A.
                      www.digitaltwins.be
                        grrr...that one looks great but it doesn't work and I see other people complain it won't install for them either.
                          Guys from rayfire just gave me an offer to buy only the brick modifier yay! So I guess I'll use that
                            That's great, how much? And don't you need the asperity modifier as well? Actually this plugin is a better (although paying) alternative for floorgenerator, albeit that most of us won't need the physics. They should release a version that bundles the fragmentation modifiers alone without the demolition system.
                            A.
                            www.digitaltwins.be
                            • #15
                              It wasn't a texture I bought, it was a modeled wall.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
