is it possible to add a system time stamp at the beginning of each line in the vray log window?
Vray Log Window
The date is there pretty nicely (though I prefer numeric for sorting purposes). It would be helpful for grepping and other text parsing tools to have the severity on every line. I would use traditional severity levels from syslog.
This is at a "small annoying things" level of importance, though.
[2016/01/08-23:12:04.43][warning] Object BigModel has overlapping triangles.
[2016/01/08-23:12:04.43][info] Loaded bitmap blah blah
[2016/01/08-23:12:04.43][info] Loaded bitmap blah blah2
[2016/01/08-23:12:04.43][info] Loaded bitmap blah blah3
[2016/01/08-23:12:04.43][warning] Object BigModel2 has overlapping triangles.
V-Ray will print "warning:" or "error:" in front of the respective messages - that should be enough for you to do what you need. If neither "warning:" nor "error:" is present, you can assume the message is an informational message.
