im using animated proxies to simplify creation of an animated assembly of parts. i animate a mesh, export it as a proxy, use the proxy as "full mesh" allowing me to continue editing it, deforming it along with other duplicates, as part of a larger grouping. this is to avoid issues with circular references and other wierdness in my animation setup.
once ive got this larger grouping animated, i wish to export the whole thing as a single larger proxy.
i cant see any technical reason why this should not work.. a mesh is a mesh.
however if i try to export a group of proxies ( edited, with modifiers on top, and "show full mesh" enabled)
i get an error "no exportable objects selected".
i can see why this would be undesirable if you are using a reduced preview mesh, but thats not the case here.
any workarounds? i kinda need this to work asap.
