GGX/Blinn/Ward and VRayEdgesTex
  • GGX/Blinn/Ward and VRayEdgesTex
    As I read in the help section and experienced myself, using the new EdgesTex in 3.3 as Bump in a GGX/Blinn/Ward shader leads to edge artifacts.
    Can we get a fix for this ASAP? I don't know why it happens but it's a major argument against using it, at least in our pipeline.
    I was so hyped seeing this but noticing that downside is like a punch int he face for me.
    I'm sure there are reasons why this isn't implemented yet, but I urge you guys to get high up on the priority list.
    Any response from CG here would be much appreciated on when/if we can expect a fix.
    Apart from that I'm really blown away (in a good way) by the new stuff in 3.3! Nice work!
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
    Do you have any example pictures of the edge artifacts you are speaking of? Because personally I haven't encountered any problems yet.
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
      Sure, here are some images
      See image name for info
      Software:
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      64GB RAM
      DxDiag
        do you have "fix dark glossy edges" enabled in the vraymtl? other than the dark outline at the back (which could be a result of your environment) i dont see any artifacts?
          There definitely are artifacts, like I said its even in the help section on the EdgesTex:
          "Currently, when used as a bump map in glossy materials with Blinn or Ward BRDF, VRayEdgesTex may lead to dark edges; to avoid this, use the Phong BRDF instead:"
          And I have it disabled with all of the BRDFs.
          Edit: My environment is what I thought first but since it doesn't happen when I use Phong BRDF with EdgesTex I am sure that it is the issue talked about in the help section.
          Software:
          3ds Max 2016 SP4
          V-Ray Adv 3.60.04
          Hardware:
          64GB RAM
          DxDiag
            you have "fix dark glossy edges" disabled? does enabling it not help?
              Doesn't make a difference.
              I heard somewhere that that checkbox has no effect afterall in GGX
              Software:
              3ds Max 2016 SP4
              V-Ray Adv 3.60.04
              Hardware:
              64GB RAM
              DxDiag
                ok then! over to Chaosgroup
                  I don't have a fix for this at the moment, unfortunately. I have no idea when it will be fixed or if it is fixable at all. I will be able to tell you more after we've done some research on the topic - which will likely take a few months at least.
                    Ok, so I was wrong, it took about 30 mins There is still some darkening at the edges, but much better than before.
                    It will be implemented for the next 3.30 patch.
                      WAY better - thanks! Looking forward to it!
                      Do you have an ETA on the next patch? (I know, I know... something like "days", "weeks" or "months" would suffice )
                      The remaining darkening at the edges could be seen as lighting/reflection changes in the environment, so that is rather not an issue I guess.
                      Software:
                      3ds Max 2016 SP4
                      V-Ray Adv 3.60.04
                      Hardware:
                      64GB RAM
                      DxDiag
